× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
What is the technical difference between extenders ex6120 and ex6920
ArizonaJim
Tutor
What is the technical difference between the ac1200 ex6120 and ex6920 extenders? I purchased ex6920's yet Netgear Geine says there ex6120's?
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: What is the technical difference between extenders ex6120 and ex6920
Hello ArizonaJim
Yes they look to be the same unit I guess it had a different model number because it was a pack of 2 extenders.
  • Two (2) AC1200 WiFi Range Extenders (EX6120)
DarrenM
Message 2 of 6
ArizonaJim
Tutor
Darren..thanks..I'm looking for the technical differences other than you can buy the dual pack ex6920's...there's a big difference in cost between the different models and configuration..can anyone add to this???
Message 3 of 6
ArizonaJim
Tutor
Darren...also the netgear genie recognizes the ex6920 as a EX6120
Message 4 of 6
DarrenM
Hello ArizonaJim
That is because it is a ex6120 are you having a issue with the setup?
DarrenM
Message 5 of 6
ArizonaJim
Tutor
Hello Darren, Ya I'm getting the same answer, To me Netgear is misleading it's customer base to use a model# implying your getting the latest device and not just a packaging of 2 model ex6120's. Thanks
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2975 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
