greens4245's avatar
greens4245
Follower
Jan 14, 2019
Wifi AC750 Range extender BLINK security cameras
Hello Everyone,
     I currently run 3 Blink security cameras at my home.  I noticed that the range on the outside garage camera is terrible and bought a Netgear AC750 wifi range extender in hopes of fixing this problem.  Here's the issue
The three camera's must be on the same wifi connection.  The inside wifi range in my home is perfectly fine and is connected to JASON WIFI
     When I connect the extender in the garage... I can't add it to JASON WIFI EXT  is there a way to trick the extender into being named the exact same, making the system think it's picking up the same wifi?
Also... I tried to hook the security system up to JASON WIFI EXT with intentions of putting all 3 cameras on the extender name.  For some reason Blink cameras find's the wifi name EXT but will not register it.  Each time when trying to connect it gives me a red light ( which means a bad connection is made)
Thank you in advance
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi greens4245,
    Just to confirm, your router's network name (SSID) is JASON WIFI EXT, correct? You can change the the network name (SSID) of the extender by logging into the extender's admin page.
    ~Christian
