Reply
Wifi router lights up all green, but no connection?
diannarizo
Follower
I recently came across my wifi router not working suddenly. All the lights on the side were lit green as they normally would when working… i unplugged, turned off and on, pressed the restart button, you name it and nothing. So i called my network provider and they said it said the wifi was connected so it was the router. All devices i would connect to being; phone, laptop, and TV all said they were connected with full bars but when i’d pull open an app it would never load or say there was no internet. So i went into the netgear app i downloaded to set it up when i first got it and went to the Routerlogin.net website to login from there, Went to the advanced tab and i rebooted it from there. Worked like magic! wifi had been down for a day and once i rebooted it on the website it instantly worked! try it…hopefully this works for you too.
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 397 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
