yls100's avatar
yls100
Follower
Jul 28, 2018
Wireless extender security on an open wifi help
I am becomming completely frustrated
Centurylink sent us a new router which we finally got connected.  Trying to reconfigure the extender with no luck
I tried Option one with WPA...when trying to connect to the EXT network...it says not connected  Open Network
I did the factory reset and still getting same message.
My extender power light and wpa? light is on.  Even the connect light is solid green so it looks like it is connected, but I still can't get on the network through my computer...I even did a direct connection with an ethernet cable.
I tried connecting to the direct IP address of the myext.net and again telling me there is no internet connection.
Century link absolutely no help at all.
  • Hi yls100,
    Welcome to the community!
    1. What is the model number of the extender?
    2. If the reset was successful, you can try going through the setup procedure as described on this link (may not be the correct model for your device).
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi yls100,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi yls100,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
