× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Wireless password but no lock symbol?
LegitJoy
Follower
I basically changed my wireless password by changing it to WPA2 from WEP/WPA. Yet, before that I had reset the factory settings (which didn't work because I could still use the original information I thought I lost but found). For my phone, I have to use a password but on my laptop I have to go to properties and put on the passcode but I don't see a lock symbol. Also, under active networks, when connected it says: 'Public Network.' I AM WORRIED AND CONFUSED. What do I do? :confused:
Message 1 of 3
Retired_Member
Not applicable
Re: Wireless password but no lock symbol?
I would start from scratch.
Press and hold reset until power led flashes, then use default credentials to access router setup and change SSID, enter a Passphrase after checking to be sure you select security setting which all your clients can use.
The public network is default WINDOWS FIREWALL settings when it detects a new connection, just change it to home in windows.
Message 2 of 3
jmizoguchi
Virtuoso
delete the wireless profile on pc first , rescan and try it
Message 3 of 3
Discussion stats
  • 2 replies
  • 8479 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
