john43
Jul 29, 2017Follower
ac750 wifi range extender
HI, Iam trying to connect my Amazon fire stick through the wifi range extender. It has found the 2 GEXT and 5 GEXT both showing strong signal. Its asking for my wifi password which iam inputting correctly but it is not accepting it. Have tried the wifi code on other devices and that is working fine. Its just when going through the range extender its not accepting it. Any suggestions please?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello John43
Did you try to use your routers main password when connected to the extender.
DarrenM
