gulluwing
Jun 12, 2016Follower
ex2700: can't connect android device to the new line with EXT extension
I have a Cisco adsl router and I installed ex2700 but the only device that connects to the new line with EXT extension is my windows pc: my android device (galaxy tab A and Huawei p8 lite) connects only to the usual connection ( not EXT). Have you any suggestion to solve this problem?
I hope you understand my problem and excuse me for my bad english.
Thanks a lot
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello gulluwing
Try to change the security type that the extender is using then tell the devices to forget the network and try to connect again.
DarrenM
