sirromdraw1's avatar
sirromdraw1
extend wifi coverage on farm
I have a netgear router in my home but ready to buy a new one so current model is irrelevant.  I have a barn that is located about 300 feet from my house and in direct line of sight (no trees or buildings in the way).  Since I am buying all equipment from scratch I am looking for a recommendation for the best router and extender or other means to broadcast a good signal to my barn and back.  Price range within reason but don't mind spending more for a good setup.  Does anyone have experience with this type of setup and need?
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi sirromdraw1
    There are many ways to extend signal to have a better coverage.
    You may want to look into getting a router and an extender such as an R9000(router) and an EX8000(extender)
    Or you may be interested of getting one of our Orbi kits
    • sirromdraw1's avatar
      sirromdraw1
      Thanks Elaine!  Both those options look promising.  Regarding the R9000 and EX8000 option the documentation talks about a "dedicated wifi link" between the router and extender or a wired access point connection.  For my scenario where the barn is about 300 feet away from my house I assume the router would be in the house and then would I place the extender also in the house but nearest to the barn or actually in the barn itself?  For the Orbi kit I'm looking at the AC2200 (with 8000 sq feet coverage) and same question.  Do I place one of the 3 satellites in the barn and can the Orbi router communicate that far away (300 feet)?  Thanks, in advance.
