Raza_25496's avatar
Raza_25496
Follower
Jun 04, 2020
netgear wirless-N 300
I FORGET PASSWORD
I WANT TO REST
HOW TO DO
I DONT HAVE CD AND CABLE
1 Reply
  • plemans's avatar
    1. Caps lock. Its to the left of the "A" key. Please use it.
    2. you don't need the cd to install it if you have the dgn2000. go to https://www.netgear.com/support/product/DGN2000.aspx and follow the install guide.
    3. if you've forgotten the password and the recover password option doesn't work, simply reset the device back to factory and re-install it. push and hold reset for 7-15 seconds while its powered on. Then re-install it using the guide from step 2.
