Papajedi's avatar
Papajedi
Follower
Dec 28, 2020
problems with Model EX6110, AC1200 extender
I bought a AC1200 wifi extender model EX6110 about 18 months ago to get wifi to my Ring door bell. it worked for  when we had a Virgin Media rounter. Since moving to Sky I cant get it to work.
Looking at the message streams I have seen similar problems around error messages - can't access any of the websites Netgear suggests.  What is most disconcerting is that the model on the official netgear you tube video doesn't even look like mine.
I just want to extend my wifi signal from the middle to the back of a relatively long, slim house.
I can't het any divice to log into the _2GEXT or 5GEXT authentication problem. I am using windows 10.
I don't want to do a short course in digital comms, I just need an idiot's guide to how to make it work.  In the old days the people who made it would do this, but now I have to turn to the community for help.  How do I get all four lights to go green?
Thanks.
1 Reply
  • plemans's avatar
    what router do you have?
    What firmware is on the extender?
    did you set it up using wps or using the installation assistant?
    I'd recommend factory resetting the extender and instalilng using the installation assistant for best results.
