KelKaiHina's avatar
KelKaiHina
rR6900/ not connecting to internet
My router will not connect to the internet, as well there is only the first 2 lights that are blinking, the rest are not... I have rebooted a few times & I keep getting the same thing.
  • plemans's avatar
    What firmware is on it?
    What modem is it connecting to?
    Is this a new product?
    did you try a factory reset (not reboot)? push and hold reset for 7-15 seconds while powered on.
    here's the support site with manual, install guides, firmware, and troubleshooting.
    https://www.netgear.com/support/product/R6900.aspx
    • KelKaiHina's avatar
      KelKaiHina
      What do you mean by firmware? Or like how do I look it up to find it?
      It is not new. I apparently purchased it in January of 2017.
      When I did press & hold down for 7-30 seconds it just kept the 2 first lights on. Nothing happened. If that makes sense ?
      I’ve also unplugged both router & modem power & waited at least 15 seconds & when I plugged both back in my modem went back on but the router still only has the first two lights on. The second button keeps blinking.
      • plemans's avatar
        What modem are you connected to?
        the first 2 lights are power and internet.
        Did you try going through setup after resetting?
