ake1000's avatar
ake1000
Follower
Nov 04, 2020
surface will not connect to extender wn2000
 I can not get my pc (surface) or my phone (android) to connect to my extender
wn2000rvp.
The extender is connected to network and shows green.
I can connect to the main router
Ive reset
down loaded
i have vhours into this
1 Reply
  • plemans's avatar
    What router did you connect the wn2000rpt to?
    what firmware is on it?
    Did you set it up using wps or using the installation assistant?
