triplexone
Apr 25, 2016Aspirant
New firmware of EX6200?
Hi everyone, I have my EX6200 running on AP mode and connected to my R7000 with the cable (firmware version=1.0.3.68). I encounterred the same problem described in the topic "EX6200 connection issues with the firmware version V1.0.3.68_1.1.104", no matter how I set for EX6200, the wireless connection speed never exceeded 54mbps. I saw the solution in that topic was to roll back to previous version, I just wonder if there will be a new firmware to solve this issue eventually (this is a huge issue in my opinion for such networking product). Downgrade to previous version should not be a final solution, isn't it?
Netgear isnt one for rapid change when they get it wrong, "looks good so it cant be all bad", WRONG.
They have had so many report this I cannot believe how poor they respond.
- triplexoneAspirant
Agree. In my opinion such bug is not acceptable for a product like EX6200, it's like having a car but only run 10KM per hour at max. I don't know if others didn't notice this issue or it only happens to some special ones.
- DarrenMSr. NETGEAR Moderator
Hello everyone
We do have a Firmware coming out soon to address this issue be sure to check for the new firmware here in the next couple weeks.
DarrenM
- triplexoneAspirantThat's an exciting news, anyway. Thanks DarrenM for updating this.
Hello triplexone
I believe the latest firmware was just released for the ex6200 if you want to try and update it. Let me know if this solves the issue.
DarrenM
Hi DarrenM, thanks for letting me know, I will definitely try it.
- triplexoneAspirantI have disabled the 2.4Ghz and did have a chance to test it. 5Ghz seems no problem here.
Hello noboundaries
You may want to try a factory reset and load the new firmware on it.
DarrenM
Tried that Darren no joy..
It came on green 2.4 and then flicked to amber .
I had a look at the browser log in and 24 mbs down form 300Mbs.
Changed channels on the router, no joy
I have disable the 2.4 for now on the router (d6300) and extender.
