Jmztaylor's avatar
Jmztaylor
Starting port number must be less than 65535
With this setting, I get that error message when applying.  No matter what number I put in the port boxes it always errors out this way.  WNDR3400V2 is the model number.  On the latest firmware available.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi Jmztaylor I didn't get the same error message. Try to factory reset and reconfigure.
    • Jmztaylor's avatar
      Jmztaylor
      Actually, I found the issue.  If you change the LAN IP address is when this issue occurs.  If you change the third octet.  And its impossible to change again without factory reset.
      • ElaineM's avatar
        ElaineM
        That's strange and that shouldn't happen.
        I was able to change on mine no problems.
        But glad to hear that you were able to save the settings.
