高级功能
21 TopicsR6850 时间安排无法工作。
购买的R6850,设置了时间安排,设置了站点限制(xiaomi.com), 主要是避免孩子看电视。 在日志中都可以看到: [site blocked: stat.pandora.xiaomi.com] from source 10.0.0.10 Monday, June 15,2020 18:59:18 [site blocked: msg.ptqy.gitv.tv] from source 10.0.0.10 Monday, June 15,2020 18:59:15 [site blocked: stat.pandora.xiaomi.com] from source 10.0.0.10 Monday, June 15,2020 18:59:15 [site blocked: data.mistat.xiaomi.com] from source 10.0.0.10 Monday, June 15,2020 18:59:12 但是还是可以使用小米盒子看~~~ 我已经升级到了最新的固件。 附件是设置截图,还请帮忙看一下。4.6KViews0likes2CommentsSmart connect 打开后,iPad,iPhone无法注册到5G-2的网络
1. Click enable Smart Connect 2. For any Android device is no issue to register on Wifi network. 3. But for Apple device, like iPhone or iPad, will not able register on Wifi properly. When it try to register on 5G-1, it will work. When it try to register on 5G-2, it will always failed . I check which network register from admin web page.3.9KViews0likes1CommentR7500 QOS does not work.
The router works with China Telecom network in Shanghai, China. i want to enable dynamic QOS and use speedtest to test the internet bandwidth. but it reports it cannot connect internet. "The Speedtest fails to detect the bandwidth, please check your Internet connection or try again later."3.1KViews0likes0Comments
