500 Nano
1 TopicPowerline 500 Nano Disconnects at least once per week (XAVB5201)
Maybe once a week I lose my internet connection. After a few minutes the connection will come back. I live in a normal sized detached house. The problem used to be even worse where it would disconnect at least once per day. When that happened I had a double wall socket with the Nano plugged into 1 socket and a surge protector plugged into the other. I thought as long as you don't plug the Nano into a surge protector and instead plug it directly into the wall socket then you would be fine. Obviously not. So I now have the Nano in 1 socket and nothing in the other socket and it now only disconnects once per week but I'd like to prevent it disconnecting at all! I've tried homeplugs by other brands and have had the same problem although Netgear seems to be the most reliable with less disconnects. Years ago I had the original 1.0 homeplug technology 10 Mbps homeplugs and I NEVER had this disconnecting problem!4.4KViews0likes3Comments
