6.8.0
6 TopicsNo apps installed or available
Ever since I updated my Nas firmware to 6.8.0, all my apps dissapeared and the available apps page is blank. I really only use one app - Resilio Sync. I downloaded that app directly from Resilio's website but it would not upload or install to my Nas. I also tried reinstalling the firmware 6.8.0 manually but have the same result. Is anyone else having this issue? Any advice? Thanks in advance, ChrisSolvedShares goes read-only after a while after upgrade to 6.8.0
Hi, After upgrading to 6.8.0 I have a strange behavior. After every boot, everything is fine for some time (up to half an hour) and then file system goes read only. After boot: root@NasSebUltra6:/# mount | grep -v snapshot | grep '(ro' tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755) After some time: root@NasSebUltra6:/# mount | grep -v snapshot | grep '(ro' tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755) /dev/md127 on /data type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=5,subvol=/) /dev/md127 on /home type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=256,subvol=/home) /dev/md127 on /apps type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=257,subvol=/.apps) /dev/md127 on /run/nfs4/home type btrfs (ro,noatime,nodiratime,nospace_cache,subvolid=256,subvol=/home) Strange thing is, there no new entry in system logs. It juste goes in readonly until next reboot. I launched a scrub just in case, but I don't really believe it will chance anything. Does anyone have some idea about how to solve this ?Solved1.5KViews0likes3CommentsReadyNAS Anti-Virus Plus - (ReadyNAS OS 6.8.0 ) - how to configure
How to set up the antivirus program behavior. My system 6.8.0 (RN102) does not show the following options. I have antivirus turned on, but it is not possible to set the antivirus in more detail. I do not want to let antivirus decide to delete suspicious files! Will someone please help me?Solved3.9KViews0likes5CommentsRN2120 - Management Service Offline + no SMB access after 6.8.0 update
HELP! I updated to 6.8.0 and now have "management service offline" and no access to SMB shares. Share is visible in MacOSX but when prompted to enter credentials the finder window disappears and does not connect.1.5KViews0likes7Comments6.8.0 Kernel warning
Hello all, There is something wrong in the was the 6.8.0 has been compiled. 6.7.5 has no such issues. Since this is a problem in the BTRFS module I believe this should be fixed asap in order to gice us the peace of mind that our data remains secure. Linux netgear-nas 4.4.79.alpine.1 #1 SMP Mon Jul 31 15:19:36 PDT 2017 armv7l GNU/Linux [20904.832521] ------------[ cut here ]------------ [20904.832536] WARNING: CPU: 0 PID: 4707 at fs/btrfs/qgroup.c:2480 btrfs_qgroup_free_refroot+0x180/0x1a0() [20904.832542] Modules linked in: vpd(PO) [20904.832555] CPU: 0 PID: 4707 Comm: kworker/u2:8 Tainted: P W O 4.4.79.armada.1 #1 [20904.832562] Hardware name: Marvell Armada 370/XP (Device Tree) [20904.832572] Workqueue: btrfs-extent-refs btrfs_extent_refs_helper [20904.832589] [<c0015f24>] (unwind_backtrace) from [<c00120dc>] (show_stack+0x10/0x18) [20904.832603] [<c00120dc>] (show_stack) from [<c0392720>] (dump_stack+0x78/0x9c) [20904.832618] [<c0392720>] (dump_stack) from [<c0024928>] (warn_slowpath_common+0x74/0xac) [20904.832631] [<c0024928>] (warn_slowpath_common) from [<c002497c>] (warn_slowpath_null+0x1c/0x28) [20904.832644] [<c002497c>] (warn_slowpath_null) from [<c0318ae0>] (btrfs_qgroup_free_refroot+0x180/0x1a0) [20904.832658] [<c0318ae0>] (btrfs_qgroup_free_refroot) from [<c028a924>] (__btrfs_run_delayed_refs+0x328/0x113c) [20904.832672] [<c028a924>] (__btrfs_run_delayed_refs) from [<c02915c8>] (btrfs_run_delayed_refs+0x60/0x2b0) [20904.832685] [<c02915c8>] (btrfs_run_delayed_refs) from [<c0291c40>] (delayed_ref_async_start+0xa4/0xb0) [20904.832698] [<c0291c40>] (delayed_ref_async_start) from [<c02dbc28>] (normal_work_helper+0x84/0x1a4) [20904.832712] [<c02dbc28>] (normal_work_helper) from [<c0037f14>] (process_one_work+0x11c/0x334) [20904.832724] [<c0037f14>] (process_one_work) from [<c0038198>] (worker_thread+0x34/0x474) [20904.832736] [<c0038198>] (worker_thread) from [<c003d20c>] (kthread+0x104/0x124) [20904.832747] [<c003d20c>] (kthread) from [<c000f568>] (ret_from_fork+0x14/0x2c) [20904.832754] ---[ end trace b127ec432b47814a ]--- And these messages are being repeated in thei thousands.5.9KViews0likes6Comments[BUG] RAID Resync Progress Output in 6.8.0
In my quest to find half usable iSCSI performance on the 3220 (https://community.netgear.com/t5/ReadyNAS-in-Business/RN3220-RN4200-Crippling-iSCSI-Write-Performance/m-p/1289066), I upgraded to FW 6.8.0, blew away the array and rebuilt it - into a RAID 10 this time - and left it re-synching overnight. I came back this morning and this is what the re-sync operation was reporting: If you jump in and out of the tab, the % and timer are still ticking. So it looks like a bug. I assume the UI update algorithm was never correctly informed that the operation was complete and the counters continued ticking.2.8KViews0likes6Comments
