AP Isolation
2 TopicsNext Orbi Firmware must allow guests to see each other but not access Lan
The Orbi Guest Network settings has checkbox option for, "Allow guests to see each other and access my local network". These TWO options must be separated as other routers do. Others before me have pointed out how having these two options treated as one is a security flaw, and defeats the whole point of having a GUEST network. Guests may want to play games with other, use their wireless printer or connect their phones to Chromecast. They should be be able to do this without having access to the entire main network. I hope that the next firmware remedies this.32KViews32likes11CommentsAny Plans for ORBI Firmware Upgrade for guests on WiFi to see each other WITHOUT accessing the LAN?
Are there plans for a firmware upgrade to the RBR50 firmware to allow guest to see ach other wihtout having acess to the main Lan? If the answer is no because this is a limitation of the product, I will start to see how to recoup my $300 dollars and sell the ORBI set. I hope that it doesn't come to that.
