Access point
22 TopicsHardwire the EX7000 instead of wirelessly connecting to the router?
I’m going to try my best to explain my current situation as best as possible since I’m not entirely tech savvy or literate. My current situation is that there are devices that need to be hardwired but the devices are located in separate rooms. One device in my room and one in my brother’s. Now I know that I can use the EX7000 to wirelessly connect to my router and just use the Ethernet ports but doing that cuts down on download speeds. So I was wondering if I can use the Ethernet port in my room and plug the extender into that so I won’t have to wirelessly connect to the router? The current set up is that we have Frontier FiOS and the ONT box is located in our garage. Not sure what that means but the employee from BestBuy said it acts as the modem so that all the Ethernet ports our house can support a router without the need of an actual modem. So currently, all we currently have the Nighthawk X6 plugged into the Ethernet port in my brother’s room and is producing a Wifi signal with internet. We now both have desktops that have no Wifi adapters. So in order to use the internet on our computer we need to be wired. We used to share a room so it was never a problem since the router was in our room but now that we have our own rooms, he kept the router while I have no possible way of accessing internet via wired connection. Since we both game, we prefer a wired connection overall for the best performance. Hence the reason why we never purchased a Wifi adapter for our PC. While trying to look up a solution for my problem, I was constantly seeing answers like using the EX7000 as an access point. However, instructions say to plug it in to a router, which defeats my purpose of buying the extender in the first place since the extender would need to be located in my brother’s room. So long story short, can I hardwire the EX7000 using the Ethernet port in my room so that it can provide internet to my devices that need to be hardwired into the extender?7.6KViews0likes4CommentsConfigure WNDR4300 as base and WNDR3700v3 as access point to create a bridge
I am trying to create a wireless bridge to connect ethernet components in one part of my home to the internet. The intenert connection comes through a cable modem connected to my wireless router WNDR4300. I want to re-purpose a WNDR3700v3 to bring the internet access to devices which do not have wireless capability (DVD Player and Roku) but have ethernet ports. I followed the instructions for each of the routers (different), but I must have missed or done something wrong, because it didn't work. Can someone help? Thanks. JuanSolvedCan't Access Router Login Page--Router in Access Point Mode
I've set my router up in Access Point mode (so that I can connect it to a wifi cable modem whose wifi has broken). Now I can't get to my WNDR3700v4 router login page. I've tried doing it over wife and by connecting ethernet cable straight from my computer to my WNDR3700v4. www.routerlogin.net doesn't work, nor www.routerlogin.com. No luck with 10.0.0.1, 10.0.0.2, 10.0.0.15, (http://192.168.1.1 or http://192.168.0.1. I've seen a few postings like this on the forum...but no solution. Help please? Thanks, AllenSolvedAdvantages/Disadvantages to using Orbi RBK50 pair as Wireless Access Points
I use an xFinity wireless router/modem for internet, wireless and VOIP. I understand that I could use the Orbi RBK50 units as access two wireless access points for this router, but am wanting to know what the advantages and disadvantages are of this and whether I would possibly be better off disabling the xFinity wifi and just going with the 2 Orbi's. I realize that going the access point route would potentially give me more coverage (3 wireless signal senders instead of 2) but wonder if I would be losing out on some functions or features by doing this. Thanks in advance.Orbi or Nighthawk with access points?
Hello, I'm really seeking some good solid advice here folks regarding upgrading my existing Apple AirPorts to a mesh or router with access point system. I'm not a big pro here, I do know some as you'll see below. But, I am definately drawn to the convenience of the mesh system all working together in one app with easy setup etc. After much effort, my Airport setup still dissapoints with frequent slow loading video, poor range overall etc. It's time to upgrade. Here's my situation: Currently: 1. I have 1 Airport Extreme and 2 Airport Expresses. Airport Extreme connects via thernet to both Expresses, cable I've run one way or another when using them as repeaters wirelessly failed miserably. It's a pretty big house I'm covering here. 2. Whats so important is that I have MANY many devices connected well beyond phones and tablets. I need a router system that can handle that. Also, I need a system that can handle playing music via AirPlay through iTunes flawlessly. Currently, my wired speakers handle it great and my 4 wireless speakers work 90% of the time, which is acceptable, barely. I've read that Orbi has had some issues with reliability when it comes to airplay, so that's a concern. Scenario 1: Orbi 1. Replace the 3 Airports with a 2 unit Orbi system. I could still keep my Airport expresses connected in bridge mode and use them for airplay speakers, connected via ethernet branched off the main router. The wifi would need to feed the rest of the wireless speakers in the house however. 2. I currently have 3 WIRED locations, and with Orbi I cannot connect them via ethernet for the backhaul, it MUST be done via wireless tri band. So, this begs the question, is Orbi SOOOO good and reliable that even running wirelessley it's better/as good as a router with wired access points? Will the backhaul required when using airplay suffer since the rest of the system is forced to use the wireless backhaul and not ethernet? Or is it all just so amazingly perfect and range extending that it will all beat the 3 Airports I have spread through my 3,000 sqft home? Scenario 2: Nighthawk plus access points 1. I could easily just swap out my existing 3 units for 1 Nighthawk AC3200 router and 2 AC1900 access points. Is there a system that is already bundled or MADE to work flawlessly together in this configuration? Netgear recommended a powerful Nighthawk but the only "access point" type device I could find was the AC1900, which is dual band while the router I would get would be 3 band. 2. this begs the question, what is the TriBand used for in a wired system? Is it used to manage traffic better or is it relatively pointless as it's there to run the backhaul for wireless devices, and since I'm wiring all 3 of them together, this Tri Band dream I'm holding onto is irrelevant? Should I just get a strong dual band with dual band extenders and call it a day? 3. Again, I'd really like this to be somewhat future proof, I don't want to bother with the wifi again for a long long time. I want it to be able to grow and handle it. I'll throw a decent amount of money at it to get that too. Please, any other model configuration or brand suggestions are VERY welcome. Lastly, I know the Eero system supports the ethernet backhaul (and maybe even the Velop). Is there a benefit to a wired mesh system OVER a wired routher/access point system? Many thanks for any advice, thanks for your time, I know it's not a short post:-) Rob I'Trying to set up DG834N router as wireless access point for an ethernet printer across Virgin WiFi.
Hello all. I've spent the last few days trawling the advice and instructions given on the web and attempting to complete this task, with much unplugging, replugging and typing of ip addresses. It seems there are lots of tutorials to set this system up with the 2nd router/access point finally being connected via ethernet to the main router but I can't do that at present and I want to know if the 2nd router/access point can be set up wirelessly? Firstly I'm Mac based OS 10.11 with a Virgin SuperHub2 as my main router and here's what i'm trying to do. I have an old DG834N router. My iMac is in my basement and my virgin router is in the room above. The iMac networking is via wifi and works fine across the dual bands. I don't have wired cabling down into my basement & I suspect the electrical ring is seperate to that above ground and therefore powerlines may not work. I recently acquired a ethernet printer (HP officejet 4500 G510g). I want to set up the DG834N as a wireless access point/repeater/bridge in order to connect the ethernet printer and then access this via the iMac and as a networked printer? I've been into the DG834N and done a factory reset (a few times), updated the firmware, set the LAN ip details to match my main virgin router SSID, WPA2, Password, Channel, disabled DCHP and selected a WDS system, most times as a wireless repeater. The furthest I have got is setting up all these details and then attempting to find the printer on the network on my iMac. I presume I need to create a second wifi setting in my network settings with a static ip address and subnet to match the DG834N settings. On occasion the iMac has seen the printer but when I try to install the printer it can't because of network issues as the second static ip address has seemingly 'knocked out' or conflicted with the original 2.4ghz wifi. When I try and seperate the wifi details it changes both at the same time i.e if I try to set the main wifi to 5G it changes the printer wifi to 5G too and the router/printer will only use 2.4g. I've tried to set up a seperate location in my network setting but it still behaves the same way. Also I get frequent, 'another device is using this ip address' messages. I have also re-booted my main router a few times and slowly restarted each device one by one. Oh and I've also connected the printer directly to the iMac to install it in a hope that this would facilitate things if I solved the network problems. Unfortunately I cannot leave the printer directly connected to the iMac permanently as there's not enough space, cabling, power etc. I realise there's a lot of different stumbling blocks (Gotcha's?) in this setup but I'd appreciate any help you can give. Thanks3.5KViews0likes1CommentNetgear wn3000rpv3 not connecting to router via ethernet
So here is my challenge: I have Belkin Router and a netgear wn3000rpv3 extender. the extnder is able to connect to the router fine through wifi and I am able to connect to my devices as well as long as I set it up as an extender. I have a 75mbps connection. by the time I get to my device via the extender.. the speeds are dropping to like 2 to 4 mbps. Hence I thought I will get a cable pulled from my router to my extender. which I did.. and here starts the challenge. My extender is not able to connect to the router as an access point. It just keeps saying " The extender can't connect to the router'. I tried a manual setup using a static Ip. but to no avail. I dont get internet from the extender. My belkin router details are as follows: IP : 192.168.2.1 Mask: 255.255.255.0 DHCP enabled from 192.168.2.2 to 192.168.2.200 Need some help and assistance of how I can setup the access point throught ethernet so I can hget faster speeds. Regards, PK.5.2KViews0likes7CommentsAmazon says EX2700 can be used as access point, thru software switch (it has no hardware AP switch)
Also, I have gathered from a few Amazon reviewers that EX2700 can easily be set up in AP Mode, by simply connecting it to wireless modum/router with ethernet cable. Can someone here provide or point me to a simple step-by-step procedure for setting up my new EX2700 (Essentials Edition) as a wireless access point? Thanks in advance for any help. hl-louisiana7.4KViews1like2CommentsConfigure route to be in the same LAN (N600 WNDR3700)
Hi, I have a Gateway router A (ProSafe (FVS336G) and a wireless router B (WNDR3700). My network topology is: (WAN IP: 10.xxx.xx.xxx) A (LAN IP: 192.168.1.xxx) <---> (WAN IP: 192.168.1.xxx) B (LAN IP: 10.0.0.xxx) <---> wireless device (IP: 10.0.0.xxx) The firmware on router B is V1.0.7.98NA. Current topology works. Every device has access to the internet. However, I need to stream data or remotely log in from device (whose IP address is 192.168.1.xxx) to device connected to router B. Now it's hard to achieve this (if possible) because wireless device is behind the router B. I am a newbie in these internet protocal stuff. I did some research online and think my option is to disable the DHCP service on B and make it an access point. However, when I go to the LAN setting pages of router B, and try to write the LAN IP as 192.168.1.xxx or try to uncheck "Use router as DHCP server", it reports conflict with WAN subnet IP. I understand it's obvious that on router B, I am setting its LAN IP in the same subnet as its WAN IP, which it's rediculous. But why unchecking the DHCP and make it an access point also doesn't work? I also saw people mentioned in other posts that the issue is using B as a DNS server. They disabled it and it works. But I don't know how to do this. I am not sure how to achieve my goal now. That is, making the ip address of every wireless device as 192.168.1.xxx, remaining in the same subnet of devices connected to A. I sincerely appreciate any suggestions! Best, YanSolved7.6KViews0likes2Comments
