Access point
27 TopicsHardwire the EX7000 instead of wirelessly connecting to the router?
I’m going to try my best to explain my current situation as best as possible since I’m not entirely tech savvy or literate. My current situation is that there are devices that need to be hardwired but the devices are located in separate rooms. One device in my room and one in my brother’s. Now I know that I can use the EX7000 to wirelessly connect to my router and just use the Ethernet ports but doing that cuts down on download speeds. So I was wondering if I can use the Ethernet port in my room and plug the extender into that so I won’t have to wirelessly connect to the router? The current set up is that we have Frontier FiOS and the ONT box is located in our garage. Not sure what that means but the employee from BestBuy said it acts as the modem so that all the Ethernet ports our house can support a router without the need of an actual modem. So currently, all we currently have the Nighthawk X6 plugged into the Ethernet port in my brother’s room and is producing a Wifi signal with internet. We now both have desktops that have no Wifi adapters. So in order to use the internet on our computer we need to be wired. We used to share a room so it was never a problem since the router was in our room but now that we have our own rooms, he kept the router while I have no possible way of accessing internet via wired connection. Since we both game, we prefer a wired connection overall for the best performance. Hence the reason why we never purchased a Wifi adapter for our PC. While trying to look up a solution for my problem, I was constantly seeing answers like using the EX7000 as an access point. However, instructions say to plug it in to a router, which defeats my purpose of buying the extender in the first place since the extender would need to be located in my brother’s room. So long story short, can I hardwire the EX7000 using the Ethernet port in my room so that it can provide internet to my devices that need to be hardwired into the extender?7.6KViews0likes4CommentsConfigure WNDR4300 as base and WNDR3700v3 as access point to create a bridge
I am trying to create a wireless bridge to connect ethernet components in one part of my home to the internet. The intenert connection comes through a cable modem connected to my wireless router WNDR4300. I want to re-purpose a WNDR3700v3 to bring the internet access to devices which do not have wireless capability (DVD Player and Roku) but have ethernet ports. I followed the instructions for each of the routers (different), but I must have missed or done something wrong, because it didn't work. Can someone help? Thanks. JuanSolvedWNR614 per estendere la rete esistente
Salve, ho collegato il Router WNR614-100PES N300 per estendere la rete di casa (sia LAN che Wi-Fi) ma non riesco a configurarlo come desidero. Premesso che lo collego al Modem-Router Wi-Fi principale (con IP 192.168.1.1) tramite cavo LAN al WNR614 riscontro questi problemi: Per la rete LAN il WNR614 fornisce ai vari pc e stampante collegati, altri indirizzi IP (10.0.0.x) e quindi non riesco a configurare stampante dai pc collegati al Modem-router principale. Per quanto rigurda la Wi-Fi del WNR614 vorrei configurare la stessa SSID e Chiave di rete del Modem-Router principale in modo da creare un'unica rete wi-fi in tutta la casa (ho provato ma in tal caso in wi-fi non funzione, si connette ma non naviga). Grazie. Diego.Solved6.6KViews0likes4CommentsCan't Access Router Login Page--Router in Access Point Mode
I've set my router up in Access Point mode (so that I can connect it to a wifi cable modem whose wifi has broken). Now I can't get to my WNDR3700v4 router login page. I've tried doing it over wife and by connecting ethernet cable straight from my computer to my WNDR3700v4. www.routerlogin.net doesn't work, nor www.routerlogin.com. No luck with 10.0.0.1, 10.0.0.2, 10.0.0.15, (http://192.168.1.1 or http://192.168.0.1. I've seen a few postings like this on the forum...but no solution. Help please? Thanks, AllenSolvedCome posso trasformare il modem router N600 DGND3700v2 in access point?
Buongiorno, io sono appena passato a fibra a casa e con il vecchio modem netgear volevo ampliare il segnale wifi del nuovo modem del che mi ha consegnato il gestore telefonico. Io possiedo il modem router N600 DGND3700v2 e pensavo di convertirlo in access point in modo da ricevere il segnale wifi trasmesso dall'altro modem e ampliarlo al resto della casa (o tramite wifi oppure ethernet, meglio se con wifi però nel caso non si potesse va bene anche via ethernet). Il problema è che non riesco a farlo. Qualche consiglio? Grazie in anticipo. Luca13KViews0likes10CommentsAdvantages/Disadvantages to using Orbi RBK50 pair as Wireless Access Points
I use an xFinity wireless router/modem for internet, wireless and VOIP. I understand that I could use the Orbi RBK50 units as access two wireless access points for this router, but am wanting to know what the advantages and disadvantages are of this and whether I would possibly be better off disabling the xFinity wifi and just going with the 2 Orbi's. I realize that going the access point route would potentially give me more coverage (3 wireless signal senders instead of 2) but wonder if I would be losing out on some functions or features by doing this. Thanks in advance.Orbi or Nighthawk with access points?
Hello, I'm really seeking some good solid advice here folks regarding upgrading my existing Apple AirPorts to a mesh or router with access point system. I'm not a big pro here, I do know some as you'll see below. But, I am definately drawn to the convenience of the mesh system all working together in one app with easy setup etc. After much effort, my Airport setup still dissapoints with frequent slow loading video, poor range overall etc. It's time to upgrade. Here's my situation: Currently: 1. I have 1 Airport Extreme and 2 Airport Expresses. Airport Extreme connects via thernet to both Expresses, cable I've run one way or another when using them as repeaters wirelessly failed miserably. It's a pretty big house I'm covering here. 2. Whats so important is that I have MANY many devices connected well beyond phones and tablets. I need a router system that can handle that. Also, I need a system that can handle playing music via AirPlay through iTunes flawlessly. Currently, my wired speakers handle it great and my 4 wireless speakers work 90% of the time, which is acceptable, barely. I've read that Orbi has had some issues with reliability when it comes to airplay, so that's a concern. Scenario 1: Orbi 1. Replace the 3 Airports with a 2 unit Orbi system. I could still keep my Airport expresses connected in bridge mode and use them for airplay speakers, connected via ethernet branched off the main router. The wifi would need to feed the rest of the wireless speakers in the house however. 2. I currently have 3 WIRED locations, and with Orbi I cannot connect them via ethernet for the backhaul, it MUST be done via wireless tri band. So, this begs the question, is Orbi SOOOO good and reliable that even running wirelessley it's better/as good as a router with wired access points? Will the backhaul required when using airplay suffer since the rest of the system is forced to use the wireless backhaul and not ethernet? Or is it all just so amazingly perfect and range extending that it will all beat the 3 Airports I have spread through my 3,000 sqft home? Scenario 2: Nighthawk plus access points 1. I could easily just swap out my existing 3 units for 1 Nighthawk AC3200 router and 2 AC1900 access points. Is there a system that is already bundled or MADE to work flawlessly together in this configuration? Netgear recommended a powerful Nighthawk but the only "access point" type device I could find was the AC1900, which is dual band while the router I would get would be 3 band. 2. this begs the question, what is the TriBand used for in a wired system? Is it used to manage traffic better or is it relatively pointless as it's there to run the backhaul for wireless devices, and since I'm wiring all 3 of them together, this Tri Band dream I'm holding onto is irrelevant? Should I just get a strong dual band with dual band extenders and call it a day? 3. Again, I'd really like this to be somewhat future proof, I don't want to bother with the wifi again for a long long time. I want it to be able to grow and handle it. I'll throw a decent amount of money at it to get that too. Please, any other model configuration or brand suggestions are VERY welcome. Lastly, I know the Eero system supports the ethernet backhaul (and maybe even the Velop). Is there a benefit to a wired mesh system OVER a wired routher/access point system? Many thanks for any advice, thanks for your time, I know it's not a short post:-) Rob I'Trying to set up DG834N router as wireless access point for an ethernet printer across Virgin WiFi.
Hello all. I've spent the last few days trawling the advice and instructions given on the web and attempting to complete this task, with much unplugging, replugging and typing of ip addresses. It seems there are lots of tutorials to set this system up with the 2nd router/access point finally being connected via ethernet to the main router but I can't do that at present and I want to know if the 2nd router/access point can be set up wirelessly? Firstly I'm Mac based OS 10.11 with a Virgin SuperHub2 as my main router and here's what i'm trying to do. I have an old DG834N router. My iMac is in my basement and my virgin router is in the room above. The iMac networking is via wifi and works fine across the dual bands. I don't have wired cabling down into my basement & I suspect the electrical ring is seperate to that above ground and therefore powerlines may not work. I recently acquired a ethernet printer (HP officejet 4500 G510g). I want to set up the DG834N as a wireless access point/repeater/bridge in order to connect the ethernet printer and then access this via the iMac and as a networked printer? I've been into the DG834N and done a factory reset (a few times), updated the firmware, set the LAN ip details to match my main virgin router SSID, WPA2, Password, Channel, disabled DCHP and selected a WDS system, most times as a wireless repeater. The furthest I have got is setting up all these details and then attempting to find the printer on the network on my iMac. I presume I need to create a second wifi setting in my network settings with a static ip address and subnet to match the DG834N settings. On occasion the iMac has seen the printer but when I try to install the printer it can't because of network issues as the second static ip address has seemingly 'knocked out' or conflicted with the original 2.4ghz wifi. When I try and seperate the wifi details it changes both at the same time i.e if I try to set the main wifi to 5G it changes the printer wifi to 5G too and the router/printer will only use 2.4g. I've tried to set up a seperate location in my network setting but it still behaves the same way. Also I get frequent, 'another device is using this ip address' messages. I have also re-booted my main router a few times and slowly restarted each device one by one. Oh and I've also connected the printer directly to the iMac to install it in a hope that this would facilitate things if I solved the network problems. Unfortunately I cannot leave the printer directly connected to the iMac permanently as there's not enough space, cabling, power etc. I realise there's a lot of different stumbling blocks (Gotcha's?) in this setup but I'd appreciate any help you can give. Thanks3.5KViews0likes1CommentDGN2200v4 (N300) come Access Point: problemi di connessione internet della sola rete guest
Buongiorno, ho un DGN2200v4 che fino a tre giorni fa ho utilizzato con soddisfazione come modem/router per una linea ADSL. L'altro ieri mi è stata intellata la fibra TIM ed il mio gateway è diventato lo Smart Modem fornitomi da TIM, allora ho deciso di riutilizzare il DGN2200v4 come Access Point. Dopo alcune vicissitudini sono riuscito a configurare il DGN2200v4 come AP e riesco a collegarmi ad esso via WiFi e anche tramite cavo ethernet con tutti i dispositivi che ho provato ed ho una perfetta connessione internet. Se però attivo sul DGN2200v4 anche la rete WiFi ospite o guest che dir si voglia allora nasce il problema: di nuovo mi collego perfettamente al DGN2200v4 tramite WiFi (guest) con ogni dispositivo, ma poi mi risulta internet non disponibile. Le impostazioni della rete guest sono le seguenti: Attiva rete guest ON (ovviamente...) Attiva trasmissione SSID ON (e infatti vedo la rete guest col nome che le ho assegnato) Consenti al guest di accedere alla rete locale ON però in realtà la casella di spunta è in grigio cioè non selezionabile e non ho trovato alcun modo per modificarla (volendo fare delle prove) Attivazione dell'isolamento wireless OFF (ho provato anche a settarla su ON, ovvero a mettere la spunta alla casella, ma il problema della mancata connessione internet dell sola WiFi guest è rimasto inalterato). la protezione è WPA2-PSK [AES], la stessa della rete WiFi "normale" del DGN2200v4, per la quale ho ancora ON la trasmissione SSID e ancora OFF l'isolamento wireless. Ovviamente ho attivato anche le reti WiFi del nuovo Smart Modem, due "normali" a 2.4 e 5.0 GHz e la sua rete guest alla quale ho dato un SSID diverso da quello della rete guest dell'AP DGN2200v4, e tutte funzionano perfettamente con connessione a internet ottima. L'unico problema è quindi l'accesso a internet collegandomi alla rete WiFi guest del DGN2200v4 usato come Access Point; quando lo usavo come gateway avendolo nello scantinato solitamente non attivavo la rete guest, ma mi pare comunque di ricordare che tale rete funzionasse e in quel caso consentisse l'accesso ad internet. Qualcuno sa spiegarmi il perché di questo problema? Cosa differenzia la rete "normale" dell'AP DGN2200v4 (che ha l'accesso a internet) dalla rete guest dello stesso AP (per la quale internet risulta non disponibile)? Può centrare la spunta della casella "Consenti al guest di accedere alla rete locale"? Ma in tal caso come è possibile modificare tale spunta visto che la casella non risulta selezionabile? Grazie dell'attenzioneSolved12KViews0likes5Comments
