Antivirus plus
1 TopicRN104 6.4.1 Anti-Virus Plus Live Scan [red-dot] disabled
I have read all the relavant discussions and cannot find a solution. Saw something about a "faint checkbox" ... not sure, but I think my setup is correct I just updated to 6.4.1 (x86) running Win 7 sp3 with all current updates and drivers. On Admin > System > Overview I show Anti-Virus Plus installed I know it is working because I got a message ... and deleted the offending .exe file Then I rebooted the NAS just to be sure ... reboot worked well. The Antivirus definition is current to today 1/27 about 15 minutes ago. I click on the link, CHECK the enable real-time scanning, click APPLY Then I click on the Antivirus Icon which bring up page //192.168.1.10/apps/avplus/admin/index.html The Live Scan [red-dot] disabled shows If I use admin > systems > settings > services > Antivirus [shows green bar] and click on it then , CHECK the enable real-time scanning, click APPLY Click the AVPlus page, press F5 to refresh, Same thing ... The Live Scan [red-dot] disabled shows Also, when I use Admin > Apps the only app installed is AVPlus. The version shows 2.0.3 Directly below that is a FAINT GRAY "ON" that will not do anything if I click it. When I click LAUNCH I get the same page //192.168.1.10/apps/avplus/admin/index.html The Live Scan [red-dot] disabled shows Is this an indication of something wrong?Solved3.1KViews0likes5Comments
