Blu-Ray
1 TopicSamsung Blu-ray player says the HTTP port is disabled
I am trying to connect my wired Samsung Blu-ray player to the internet and I keep getting the message that the HTTP port is disabled. I have tried assigning its own IP address and also entering the router settings manually into the player. Nothing works, so I’m looking for suggestions.Solved88KViews0likes11Comments
