CM1000
1 TopicOrbi WiFi System (RBK53) AC3000
I am considering purchasing the Orbi WiFi System (RBK53) AC3000 system along with the Netgear CM1000 docsis 3.1 cable modem. Is anyone running this setup? If so, have you experienced the random network drops that some have mentioned? Also, is there a limit to how many satellites can be added before a reduction in speed occurs? I want the router and 3 satellites provided that the addition of the 3rd satellite won't cause a performance drop. Thanks in advance for your help!Solved
