CM1000
19 TopicsCM1000 is it the Modem or provider
I have been having a problem for the last week or so that it loses internet connection even though all the modem lights show everything is good. It happens every 2-3 hours and if I power cycle the modem it works again for another 2-3 hours. When it loses internet I can unplug the ethernet cable going to my router and plug it into my PC directly but it still does not have internet until I power cycle it again. These are the current readings. Does this seem like it is the cable provider issue(signal quality or other) or a failing modem? Thanks98Views0likes11CommentsCM1000 w/ R7000P
Hi I’ve had my modem and router for a couple of years. Everything was working fine till couple months ago my internet has been buggy. I noticed the modem upstream light will blink green then stop. Now the upstream is solid amber. I did two power cycles however the upstream remains solid amber. My internet is working so not sure if my devices or my ISP. Does anyone know a solution? Do I need to have my ISP come out to check the lines or do I need a new modem or router?1.1KViews0likes45CommentsNetgear Genie App in NG Modem CM1000v2
I am using the Netgear AX1800 Wi-Fi 6 Router with the Netgear CM1000v2 Cable modem. A few weeks ago I started having problems with logging into the cable modem with Netgear Genie. In browsing the internet I found that there were many people having this problem. I discovered that the Genie app was now obsolete and would no longer be updated. Windows 11 Edge browser reported that it had no certificate. Logging in with username and password resulted in a new login screen popping up. Clicking on the site information lock icon issued a warning that it was not safe. It also did not give you a choice for continuing to the site. Like all of the people posting on the internet with this same problem said, ... HOW am I going to get into my cable modem to view the information there were times when trying to login a prompt would pop up and say the login attempt was rejected. I tried searching the web for adding a certificate for the Genie login app that the browser said was missing. I read many posts and reviews of this problem on the internet, but most people said the suggestions they found did not work. Most of them involved rebooting the modem, doing a hard reset on the modem and doing the same thing with the router. Like everyone else I kept wondering what was wrong. My system setup with modem, router, and other devices are working great with good speeds, so why should I be concerned about not being able to log in to the modem, if it works don't try to fix it. But I could not except this thought as I like to be able to access all of my equipment and devices. But all of the crazy things going on with being able to access the CM1000v2 cable modem with the Genie app was getting to me and I could not let it go. I FOUND A SOLUTION. To all of the people out there searching for a solution to this problem. I did not find it to be with my ISP, nor my service line, nor my modem, nor my router, nor my PCs, nor my OS, nor my browser, nor missing certificates, nor my Genie app or any of those things. I blush to tell you this and I know that your problems and solutions may be entirely different from mine. I found that when digging through some old files a password that was set for my Netgear Genie app login to the Netgear CM1000v2 cable modem. I tried this password and now everything is working beautifully as it should be. Some how the password got changed for the Genie app login for the modem which resulted in all the problems and headaches trying to resolve the problem. Sometimes some of us don't think about the little simple things, it always has to be big, mind-blowing problems that involve many associated things that we have to search and search for answers to. I sure learned a big lesson in my older years. I hope you moderators don't mind posting this for a little amusement as well as a little help for some with this same problem. Thank you for your time.196Views0likes1CommentUnable to connect after power outage
So to my knowledge, we had just recently had a brief thunderstorm last night while I was at work. When I returned home our wifi was out and did not return after multiple reboots. This morning I had done extensive searching to try and troubleshoot the issue, with multiple power cycles to our Netgear CM1000 modem and our Tp-Link Archer AX21 router. I have even tried to factory reset both the modem and router to no resolve of the issue. For now, the indicator lights on the modem are all static green for power, downstream, upstream and internet. No lights will turn on for the ethernet despite multiple different cables connected securely. The lights will however blink orange once during reboot. For the router only the power button is solid green, with the occasional rest of the lights flashing green except for the internet flashing orange. I have also done troubleshooting with Spectrum to which they stated there is no issue with the ISP and that it may be a router/modem issue.295Views0likes1CommentCM1000 Xfinity issues
I am quite frustrated at this point. I had a CM600 modem to support Comcast's Extreme 150 service. I've had it for a few years and was consistently getting 160 to 170mbps speed from it. About three weeks ago, I noticed a drop off and did a speed test and could not get more than 50mbps. Comcast reset the modem (I did the same thing). No change. They sent a tech out to the house and he swapped out my modem for one of theirs and lo and behold, 170mbps. He said I needed a new modem. I was a little suspicious of this, but wanting to eventually get gigabit service when it becomes available, I bought a CM1000. It provisioned fine, but I am seeing the same behavior. At the start of the speed test it spikes to over 100 but eventually averages out to 70 or 80. They came out again and re-trenched a new thicker line between the street and the house. Still the same behavior. The tech came out again today and installed a dedicated line directly from the outside box to the modem. Still the same behavior. The logs from the Modem are consistently showing: Time Priority Description 2017-12-03, 10:41:31 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 21 22 ; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=b0:39:56:4b:b8:68;CMTS-MAC=00:01:5c:a7:12:4e;CM-QOS=1.1;CM-VER=3.1; 2017-12-03, 10:41:17 Warning (5) MDD message timeout;CM-MAC=b0:39:56:4b:b8:68;CMTS-MAC=00:01:5c:a7:12:4e;CM-QOS=1.1;CM-VER=3.1; The Cable Connection page displays the following. Any thoughts on this issue? Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure Procedure Status Comment Acquire Downstream Channel 555000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 20 555000000 Hz 2.8 dBmV 36.8 dB 158493311 546 0 2 Locked QAM256 1 423000000 Hz 5.4 dBmV 38.7 dB 157105990 36 0 3 Locked QAM256 2 429000000 Hz 5.6 dBmV 38.9 dB 157114932 13 0 4 Locked QAM256 3 435000000 Hz 5.6 dBmV 39.0 dB 157125743 17 0 5 Locked QAM256 4 441000000 Hz 5.1 dBmV 38.7 dB 157134245 29 0 6 Locked QAM256 5 453000000 Hz 4.2 dBmV 38.5 dB 157143868 60 0 7 Locked QAM256 6 459000000 Hz 3.8 dBmV 38.3 dB 157153008 71 0 8 Locked QAM256 7 465000000 Hz 3.5 dBmV 38.3 dB 157162210 62 0 9 Locked QAM256 8 471000000 Hz 3.2 dBmV 38.2 dB 157171891 72 0 10 Locked QAM256 9 477000000 Hz 2.7 dBmV 38.0 dB 157181040 59 0 11 Locked QAM256 10 483000000 Hz 2.2 dBmV 37.5 dB 157190267 74 0 12 Locked QAM256 11 489000000 Hz 2.0 dBmV 37.4 dB 157199468 75 0 13 Locked QAM256 12 495000000 Hz 1.9 dBmV 37.4 dB 157208618 80 0 14 Locked QAM256 13 507000000 Hz 1.7 dBmV 37.3 dB 157218872 61 0 15 Locked QAM256 14 513000000 Hz 1.6 dBmV 37.3 dB 157227558 70 0 16 Locked QAM256 15 519000000 Hz 1.4 dBmV 37.3 dB 157237136 95 0 17 Locked QAM256 16 525000000 Hz 1.1 dBmV 37.1 dB 157246947 121 0 18 Locked QAM256 17 531000000 Hz 1.3 dBmV 37.4 dB 157255633 105 0 19 Locked QAM256 18 537000000 Hz 1.3 dBmV 37.1 dB 157264694 132 0 20 Locked QAM256 19 543000000 Hz 1.6 dBmV 37.1 dB 157275272 112 0 21 Locked QAM256 21 561000000 Hz 2.9 dBmV 32.3 dB 147085863 2537135 7646772 22 Locked QAM256 22 567000000 Hz 3.6 dBmV 27.2 dB 135579752 4471561 17201032 23 Locked QAM256 23 573000000 Hz 3.7 dBmV 35.5 dB 152906954 3458380 927827 24 Locked QAM256 24 579000000 Hz 3.1 dBmV 34.7 dB 157299415 177 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 35600000 Hz 35.8 dBmV 2 Locked ATDMA 2 29200000 Hz 35.8 dBmV 3 Locked ATDMA 3 22800000 Hz 34.0 dBmV 4 Not Locked Unknown 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1 25 372000000 Hz 7.6 dBmV 38.3 dB 1108 ~ 2987 4381967 35743 0 2 Not Locked 0 0 0 Hz 7.2 dBmV 0.0 dB 0 ~ 4095 0 0 0 <tabindex=-1>Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV Any help or guidance I can give Xfinity would be greatly appreciated. I really want to own my own equipment and not pay $10 a month for their stuff. Warm regards, JoeSolved79KViews0likes78CommentsXR500 and cm1000
Hey all I just bought the xr500 its pretty cool so far ,But i am having a slight hicup . If i restart my cm1000 the light on the xr500 goes amber even when the modem gets full back up it stays amber . I am wondering if maybe I got a bad xr500 or if its a glitch When i got the webpage for the modem It will not detect my modem till I unplug the router and power it back up.Solved8.9KViews0likes19CommentsIntermittent connection problems
I am looking for help diagnosing intermittent connectivity issues with my CM1000 modem. I am not sure what clues I should be looking for and I have not been able to detect any patterns to indicate cause. Let me offer some details… I am an Xfinity customer in my home, and I have been using a Netgear CM1000 modem for around 6 months. Everything worked great for the first 5 months. However, the last month I have been getting hit with maddening intermittent connection problems. I lose all internet connectivity and cannot ping anything on the internet for short periods of time. These issues usually just last a minute or two, but sometimes as long as 5 minutes. Network connectivity eventually comes back without any intervention from me. Some days I have no connectivity issues, other days it happens several times (usually in the most in-opportune times!). I have not noticed any change in the modem lights when this occurs. When I call Xfinity/Comcast support their only suggestion is to reboot the modem. That usually causes the connection to be restored, but I don’t think that is really fixing anything – like I said the connection issues usually only last a minute or two anyways. The agent I talked to at Comcast said she cannot see anything else on her end. Since I own my own modem, she stated it will likely cost me money to have a tech come out and look at it. Before I break down and have someone come out, I wanted to search for some evidence that is or is not a modem problem. I’m not against buying a new modem either, but am going to be frustrated if I have the same problems. This behavior occurs on multiple computers - both wireless and wired – which leads me to believe it is a network issue. I swapped out my router for a few days just to see if it was possibly a router issue. The same issues occurred with the replacement router, so I think I can rule that out as well. I did chat with my good friend Google a bit and learned to check the power levels. The power levels seem ok as they fall between the -7 to 7 range for downstream and 38-48 for upstream. I haven’t touched any cables lately, but did double check the cables I had access to to make sure they were connected tightly. My Hardware version is 2.02 and firmware version is V3.01.04. I understand that Xfinifity/Comcast controls pushing out the firmware updates so there is not much I can really do about adjusting firmware. I do have an older (slower) modem I suppose I could go back to for a while and see if I have problems with that. Any thoughts/ideas would be appreciated.1.6KViews1like1CommentNot getting correct speed with Comcast
Hello all In November I saw that Comcast offered a higher tier internet service in my neighborhood. Speeds are advertised up to 986 Mbps. Since I signed up I’ve only seen 350-400 Mbps. I had a couple of online chats and phone calls with Comcast. I also had two techs come to the house to check the signal to the house. The second tech said that Comcast had to approve new firmware for my CM1000 modem (this was in December). He said that once Comcast approved the firmware then Netgear would push the upgrade to my modem directly. I called to try to get credit for billing since I wasn’t getting the correct speeds and I was forced to chat with Comcast tech support again. The tech sent me a link to the Nighthawk X6 router firmware page to update my CM1000 cable modem :| When I told them it was the wrong equipment they told me to contact Netgear directly to receive my firmware update. I sent this link to him. https://www.netgear.com/support/product/CM1000#download It says “Current Versions Firmware upgrades are pushed down by your ISP. For more information, please see our Knowledge Base .” He just told me to talk to Netgear :| Has anyone had any success getting advertised speeds with Comcast Gigabit Internet? Thanks for your time13KViews0likes6CommentsCM1000 + Orbi (RBK50) on Xfinity - Constant Disconnects
Hello there, I am having similar problems to ones on this board - Constant disconnects on the Orbi platform with a CM1000 modem on Xfinity. A Comcast tech has been by, checked the levels and left saying everything's fine with the incoming line. It works great when it does ( Blast tier - ~200 - 250 Mbps) but the disconnects are getting out of hand. They last a few seconds at a time to ~6 minutes at a time (most common) if left unattended - Rebooting the modem/router fixes it in a minute and a half (even that's not consistent of late). Details: CM1000 Hardware Version 2.02 Firmware Version V3.01.04 Orbi RBK50 Router Firmware Version V2.1.1.16 uPnP OFF,Daisy Chaining Disabled, MU-MIMO and Implicit Beamforming Enabled, Fast Roaming Disabled I am attaching logs and event logs from the modem and router if at all it helps nailing the problem(s). Please let me know what else I can do before returning either/both modem and router.1.3KViews0likes1Comment
