SoCalLV's avatar
SoCalLV
CM1000 w/ R7000P
Hi
I’ve had my modem and router for a couple of years. Everything was working fine till couple months ago my internet has been buggy.  I noticed the modem upstream light will blink green then stop. Now the upstream is solid amber. I did two power cycles however the upstream remains solid amber. My internet is working so not sure if my devices or my ISP. Does anyone know a solution? Do I need to have my ISP come out to check the lines or do I need a new modem or router?
    • SoCalLV's avatar
      SoCalLV
      Hi thank you getting back to me here you go:
      • FURRYe38's avatar
        Need to see the data from the cable connections page and event logs please.
  • Frequency start Value
    This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
    Starting Frequency
    Startup Procedure
    ProcedureStatusComment
    Acquire Downstream Channel759000000 HzLocked
    Connectivity StateOKOperational
    Boot StateOKOperational
    SecurityEnableBPI+
    IP Provisioning ModeHonor MDDIPv4 only
    • SoCalLV's avatar
      SoCalLV
      Downstream Bonded Channels
      ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
      1LockedQAM2565759000000 Hz8.7 dBmV42.6 dB8771869800
      2LockedQAM2561735000000 Hz8.7 dBmV42.6 dB9106737800
      3LockedQAM2562741000000 Hz8.7 dBmV42.6 dB9107406200
      4LockedQAM2563747000000 Hz8.7 dBmV42.6 dB9107775000
      5LockedQAM2564753000000 Hz8.7 dBmV42.6 dB9108161400
      6LockedQAM2569783000000 Hz9.1 dBmV42.7 dB8685403200
      7LockedQAM2566765000000 Hz8.9 dBmV42.6 dB9108867700
      8LockedQAM2567771000000 Hz9.1 dBmV42.7 dB9109298700
      9LockedQAM2568777000000 Hz9.1 dBmV42.8 dB9109631700
      10LockedQAM25610789000000 Hz9.0 dBmV42.8 dB8688490200
  • 11LockedQAM25611795000000 Hz8.9 dBmV42.7 dB8689237200
    12LockedQAM25612801000000 Hz9.0 dBmV42.7 dB8689921300
    13LockedQAM25613807000000 Hz9.1 dBmV42.7 dB8690672000
    14LockedQAM25614813000000 Hz9.2 dBmV42.7 dB8691486600
    15LockedQAM25615819000000 Hz9.1 dBmV42.8 dB8692225900
    16LockedQAM25616825000000 Hz9.1 dBmV42.8 dB8692950300
    17LockedQAM25617831000000 Hz9.1 dBmV42.7 dB8693717500
    18LockedQAM25618837000000 Hz9.1 dBmV42.7 dB8694438900
    19LockedQAM25619843000000 Hz9.4 dBmV42.9 dB8695210000
    • SoCalLV's avatar
      SoCalLV
      20LockedQAM25620849000000 Hz9.5 dBmV43.0 dB8695908900
      21LockedQAM25621855000000 Hz9.7 dBmV43.0 dB8696701500
      22LockedQAM25622861000000 Hz9.7 dBmV43.1 dB8697450300
      23LockedQAM25623867000000 Hz9.6 dBmV43.0 dB8698020900
      24LockedQAM25624873000000 Hz9.8 dBmV42.9 dB8698428900
      25LockedQAM25645237000000 Hz3.9 dBmV41.7 dB8698934900
      26LockedQAM25641213000000 Hz4.1 dBmV41.9 dB9115957000
      27LockedQAM25642219000000 Hz3.8 dBmV41.8 dB9116315000
      28LockedQAM25643225000000 Hz3.9 dBmV41.9 dB9116713000
      29LockedQAM25644231000000 Hz3.9 dBmV41.9 dB9117012000
      30LockedQAM25646243000000 Hz3.9 dBmV41.9 dB9116824900
      31LockedQAM25647249000000 Hz4.0 dBmV41.8 dB9116893900
      32LockedQAM25648255000000 Hz4.0 dBmV41.6 dB9116857800
      • SoCalLV's avatar
        SoCalLV
        Upstream Bonded Channels
        1LockedATDMA136300000 Hz43.3 dBmV
        2LockedATDMA229900000 Hz43.3 dBmV
        3LockedATDMA323500000 Hz43.3 dBmV
        4LockedATDMA416900000 Hz43.3 dBmV
        5Not LockedUnknown00 Hz0.0 dBmV
        6Not LockedUnknown00 Hz0.0 dBmV
        7Not LockedUnknown00 Hz0.0 dBmV
        8Not LockedUnknown00 Hz0.0 dBmV
    • FURRYe38's avatar
      Can we get the Event Logs page data as well.
      Power for some of our channels is too much and too high.
      https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
      I'd day get a -3 or -6dbm cable coax line attenuator installed.
      SoCalLV wrote:
      11 Locked QAM256 11 795000000 Hz 8.9 dBmV 42.7 dB 86892372 0 0
      12 Locked QAM256 12 801000000 Hz 9.0 dBmV 42.7 dB 86899213 0 0
      13 Locked QAM256 13 807000000 Hz 9.1 dBmV 42.7 dB 86906720 0 0
      14 Locked QAM256 14 813000000 Hz 9.2 dBmV 42.7 dB 86914866 0 0
      15 Locked QAM256 15 819000000 Hz 9.1 dBmV 42.8 dB 86922259 0 0
      16 Locked QAM256 16 825000000 Hz 9.1 dBmV 42.8 dB 86929503 0 0
      17 Locked QAM256 17 831000000 Hz 9.1 dBmV 42.7 dB 86937175 0 0
      18 Locked QAM256 18 837000000 Hz 9.1 dBmV 42.7 dB 86944389 0 0
      19 Locked QAM256 19 843000000 Hz 9.4 dBmV 42.9 dB 86952100 0 0
      • SoCalLV's avatar
        SoCalLV
        Here you go. Seeing a lot of critical.
        The coax line attenuator is that something I need to connect my ISP or can I do it myself. Where would I replace the attenuator?
        2026-01-06, 21:13:22Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        2026-01-06, 21:12:34Notice (6)US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 9 13.;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        2026-01-06, 21:11:41Critical (3)No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        2026-01-06, 21:11:39Warning (5)Dynamic Range Window violation
        2026-01-06, 21:11:39Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        2026-01-06, 21:11:39Warning (5)RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        2026-01-06, 21:11:38Critical (3)No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        2026-01-06, 21:11:32Notice (6)DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        2026-01-06, 21:11:30Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        2026-01-06, 21:11:25Notice (6)TLV-11 - unrecognized OID;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
        Time Not EstablishedWarning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=c8:9e:43:72:2f:60;CMTS-MAC=04:76:b0:24:4c:ef;CM-QOS=1.1;CM-VER=3.1;
  • Downstream OFDM Channels
    ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
    1Locked0, 1, 2, 3159300000000 Hz5.4 dBmV41.0 dB296 ~ 789526158032212182480
    2Locked0, 1, 2, 3160918000000 Hz10.3 dBmV41.8 dB2216 ~ 59752745082890265360
  • I apologize for multiple messages. It wouldn't let me copy/paste or upload images. Additionally, my modem has been acting up and keeps rebooting. I'll power cycle and reset everything, it will load up, then do it again. I have to reset a couple of times before it stops. Right now it's fine, but I know in a couple of days it will act up.
    When I log into Netgear, it shows I'm on Firmware Version V10.01.07, and I'm with COX internet.
    pstream OFDMA Channels
    1Locked3, 4, 9, 10, 11, 12, 13636800000 Hz38.5 dBmV
    2Not Locked3, 4, 9, 10, 11, 12, 1300 Hz0.0 dBmV
    • SoCalLV's avatar
      SoCalLV
      Hi yes, its the same thing, it just got cut off. How do I unlock it?
  • CrimpOn's avatar
    CrimpOn
    While I DID crimp some coax connectors 30 years ago, I have NO IDEA.  I would start with calling Cox technical support and saying, "my modem says that the upstream channel is not 'locked'.  Is this something your tech can fix?"
    p.s. My guess is that this means your upstream bandwidth is half what it is supposed to be.
  • Thank you, I'll contact my ISP. Do you think it has to do with the lines inside or outside my house, given that I have warning and critical event logs?
    • CrimpOn's avatar
      CrimpOn
      My guess would be outside.  Cable techs are REALLY good at checking things.
  • FURRYe38's avatar
    You got some channels that are too High in power some that are in the opposite direction but with in the power range:
    Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    Be sure to power OFF the modem for 1 minute then back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
    https://highspeed.tips/docsis-events/
    • SoCalLV's avatar
      SoCalLV
      I'm having them come out again tomorrow to recheck everything. I'll let you know.
