CM1000
2 TopicsXR500 and cm1000
Hey all I just bought the xr500 its pretty cool so far ,But i am having a slight hicup . If i restart my cm1000 the light on the xr500 goes amber even when the modem gets full back up it stays amber . I am wondering if maybe I got a bad xr500 or if its a glitch When i got the webpage for the modem It will not detect my modem till I unplug the router and power it back up.Solved9.1KViews0likes19CommentsNetgear R7000 isn't up to speed on a gigabit connection through CM1000 modem
Hi, I recently got a Netgear CM1000 modem on my gigabit Xfinity connection. When I hook my laptop up to the modem directly I am getting close to a gigabit connection, at least above 900 Mbps consistently. But when I hook up (ethernet) through my R7000 with fully upgraded stock firmware I'm still just getting around 200 Mbps which is the speed I used to have before my connection was upgraded. What could the reason be for me not getting any speed increase when connecting through the router? As far as I can see the the router should be able to handle the speed.Solved16KViews0likes5Comments
