Captive Portal
2 TopicsPR2000 support captive portal wireless login page?
Hi everyone. I've read the manual and attempted to ask Support, but have not found the answer to this. https://www.netgear.com/home/products/networking/wifi-routers/PR2000.aspx Does the PR2000 support captive portal wireless login pages? These are web pages for public wifi networks where you need to take some action on the page, like checking a box, in order to connect to the network. The PR2000 interface allows you to connect to wifi networks with a UN/PW, but it doesn't appear to support a browser interface in order to get past the login page of the wifi network you want to connect to? Does anyone know if the PR2000 supports this? If so, how? If it doesn't it really limits the usefullness of the device. Thanks in advance!1.2KViews0likes1Comment
