Configuration
1 TopicQuestions about the GS748T or GS750E
Hoping for a little help\advice. I currently have a GS105E Netgear ProSAFE Plus Switch. It's a simple 5-port switch that allows me to accomplish something with my very small business very easily. If your not familair with this model, it has a very simple port vlan setup that makes it easy to keep computers from communicating with each other, but still share the internet access. I can plug my gateway\modem into port 1 and then go thru the web interface and configure each port to communicate with port 1, but not each other or if need be another port. It doesn't require any fancy vlan configuration or special routers that are vlan aware. It just allows me to configure things on a port basis. I now need to upgrade my switch to a 48-port switch as I move from a very small business to a small business, but I would like to have the same simiple port vlan options. I don't want to have to buy a special gateway router that needs configured or have to have a degree in networking to make it all work. Are there any Netgear 48-port switches that offer the same ease in configuration as the GS105E? I was looking at the GS748T or the GS750E as possibilities, but want to make sure what I am getting into before I buy one. I thought maybe the GS750E might be what I need because it is in the same family line as my current GS105E so the configuration options might be the same but I can't find any solid information on it. Any help would be greatly appreciated, JoeSolved
