Connection problems
1 TopicAC1200 Choppy connections, Had N600 Dual-Band, was fine
Well I had a WNDA3100v2 – N600 Wireless Dual Band USB Adapter before and it crapped out on me. Looks like it just went dead from years of use. I went to the store and bought the current model that I'm using, the AC1200, I started to experience choppy connections online while gaming. The N600 was fine, no connection issues and only slowed down if other people were heavily using the net. Now my ping time in game is 10-20ms but i'm experiencing spikes where the connection is choppy. I look and I see no fluctuation of ping. Streaming videos is fine, downloads are fine. I installed the new drivers without the genie right off the bat and it was spiking. I then installed the genie to see if it would fix it. Did not work. Reset the router. Still spiking. I'm about to go return it. It seems like it's a hardware issue, weird how the lesser model outperforms.3.4KViews0likes1Comment
