DHCPV6-PD
1 TopicConnecting to Comcast with IPv6
So I am replacing my Asus rt-ac87u with the ProSafe firewall. The Asus is reconfigured to be just an access point. Everything is up with the exception of ipv6. From what I am seeing/reading, there seems to be a problem with the FVS318G in that it is only sending one ipv6 DHCPV6 request. Thing is, I need to request the IP for the WAN (stateful DHCPV6) and request the prefix delegation for the LAN (stateless DHCPV6-PD). This worked perfectly with my Asus. On the Netgear, I am unable to select Prefix Delegation if stateful is selected for DHCPV6. grrr. I'm pretty sure, if I could get the Netgear to send that PD request when doing stateful, it will also receive the delegated network that can be used on the LAN. Has anyone successfully got this box to connect to Comcast via IPv6 and do delegation/routing? Brian AndrusSolved4.2KViews0likes3Comments
