Device Limits
1 TopicWPA Key limitations ORBI wifi router
Is the number of active simultaneously connected devices connected to an Orbi router limited by the number of WPA keys it can support? Are the 50 streaming devices assumed to be streaming with encrypted links? Is the 50 limit per Orbi unit? Where are the device limits documented? Thank you, Chris
