Extender Mode
2 TopicsModel EX6000 unable to enter Extender mode
Just bought an EX6000 and am beginning to set it up. I placed the extender into the same room as the router and plugged it in. On plugging it in, the Power LED is Orange. WPS/Mode LED is off. * Press the Power on/off button. * Power light becomes green. WPS/Mode LED still off. * Press WPS/Mode Button for more than 5 seconds. * Power light turns orange. WPS/Mode Button blinks green. * Power light turns green. WPS/Mode Button turns off. The Extender doesn't seent to want to enter Extender mode - can anyone help with this? Is this a faulty device?3KViews0likes5CommentsEX3800 Extender mode (WPS) won't go off
EX3800 won't switch from extender mode to access point mode ONLY. "WPS" light is always on, no matter what I do. "Router" -light also turns on, so access point mode is starting, but same time "WPS"-light is still green. I have tried to push WPS-button for 5 sec so that green light starts to blink. Power-light goes orange, and turns to green after a while. But after blinking, WPS-light is always on, while router-light gets off and on, switching normally as it should. According to manual, WPS-light and router-light shouldn't be green at same time. EX3800 is connected to Netgear WiFi-router with ethernet-cable, from main building to another. I need to expand my Wi-Fi with cable, because with extender mode the EX3800 can't reach the router on air. I made setup first time, by connectin EX3800 to router in same room with short cable. Setup worked out fine. Router light was on, WPS off and everything worked nicely. Then I moved EX3800 to another building and made same cable-connection. Only difference is that cable lenght is longer, as I use ethernet sockets in walls. EX3800 found the router as earlier, but now the WPS light won't go off. I also pushed factory reset and made setup again. Same result, WPS light is green and won't go off. (NGEX3800ACRP, firmware updated)3.5KViews0likes2Comments
