Fan error problem not spinning
1 TopicWeird Fan Problem on RNDP6000 with 6.4.1 - Solution did last :(
Hello, Well, after making the changes to my config file, the system fan has gone back to not spinning except at boot time. All I would like to ask Netgear support is how do I permanently turn my fan on, even at full speed is fine because my NAS is in the basement and the noise won't be a problem. Surely there is a way to do this? I assume that it would involve a change to the /etc/sensors.d/system.conf file? What is the syntax to turn the fan on forever, not worry about temperature control and cycling it, just turn on full blast indefinitely? Thanks for the help, it would be nice if we had details about the syntax for that file? I can sort of figure out some of it, but without official instructions, I am afraid to make changes beyond what I have done already... Thanks, David PS -Here is my current file: root@RNDP6000:/etc/sensors.d# more system.conf chip "coretemp-isa-0000" label temp2 "CPU" chip "w83627dhg-isa-*" label in1 "DDB18" set in1_min 1.62 set in1_max 1.98 label in2 "AVCC" set in2_min 3.3 * 0.90 set in2_max 3.3 * 1.10 label in3 VCC3 set in3_min 3.3 * 0.90 set in3_max 3.3 * 1.10 label in4 VCC1_25 set in4_min 1.17 set in4_max 1.32 label in5 "VCC1_5" set in5_min 1.41 set in5_max 1.58 label in6 "VCC1_05" set in6_min 0.98 set in6_max 1.10 set in7_min 3.3 * 0.90 set in7_max 3.3 * 1.10 set in8_min 3.0 * 0.90 set in8_max 3.3 * 1.10 label fan1 "System" set fan1_min 600 label fan2 "CPU" set fan2_min 150 label fan3 "System" set fan3_min 1600 ignore fan4 ignore fan5 label temp1 "System" set temp1_max 80 ignore temp3 ignore cpu0_vid ignore intrusion0 ignore fan3Solved3.2KViews0likes2Comments
