howarddavidp
Dec 22, 2015Tutor
Weird Fan Problem on RNDP6000 with 6.4.1 - Solution did last :(
Hello,
Well, after making the changes to my config file, the system fan has gone back to not spinning except at boot time.
All I would like to ask Netgear support is how do I permanently turn my fan on, even at full speed is fine because my NAS is in the basement and the noise won't be a problem. Surely there is a way to do this?
I assume that it would involve a change to the /etc/sensors.d/system.conf file? What is the syntax to turn the fan on forever, not worry about temperature control and cycling it, just turn on full blast indefinitely?
Thanks for the help, it would be nice if we had details about the syntax for that file? I can sort of figure out some of it, but without official instructions, I am afraid to make changes beyond what I have done already...
Thanks,
David
PS -Here is my current file:
root@RNDP6000:/etc/sensors.d# more system.conf
chip "coretemp-isa-0000"
label temp2 "CPU"
chip "w83627dhg-isa-*"
label in1 "DDB18"
set in1_min 1.62
set in1_max 1.98
label in2 "AVCC"
set in2_min 3.3 * 0.90
set in2_max 3.3 * 1.10
label in3 VCC3
set in3_min 3.3 * 0.90
set in3_max 3.3 * 1.10
label in4 VCC1_25
set in4_min 1.17
set in4_max 1.32
label in5 "VCC1_5"
set in5_min 1.41
set in5_max 1.58
label in6 "VCC1_05"
set in6_min 0.98
set in6_max 1.10
set in7_min 3.3 * 0.90
set in7_max 3.3 * 1.10
set in8_min 3.0 * 0.90
set in8_max 3.3 * 1.10
label fan1 "System"
set fan1_min 600
label fan2 "CPU"
set fan2_min 150
label fan3 "System"
set fan3_min 1600
ignore fan4
ignore fan5
label temp1 "System"
set temp1_max 80
ignore temp3
ignore cpu0_vid
ignore intrusion0
ignore fan3
This fixed it my RNDP6000 (from the other thread):
echo 2000 > /etc/frontview/min_fan_speed_override
Funny thing is, even though my fans don't run at 2000, they run at their normal speeds, and they don't make noise. I thought they would go to full blast at 2000, but they just run normally, when I reboot I can hear them at full speed, but once booted they run 100% normal.
Wonder why this is the case? Obviously they don't try and stay at 2000rpm? I would hear it if they did. I had a molex inline 4 pin fan adapter that I was going to install on one of the hard drive power connectors if I could not figure this out, glad I don't have to use it. Anyone at Netgear care to take a stab at why this works? I don't care, just glad I am all fixed up after multiple trial and error attempts to get it working again. My system also does not show DEAD as a status now that both fans are running.
David
David
- mdgm-ntgrNETGEAR Employee Retired
Perhaps the minimum fan speed was set so low that in trying to reduce the fan speed to that, the fan stopped and the system considered the fan to be dead.
