Firmware Updates
5 TopicsM1 (MR1100) needs battery to update firmware
My suspicions expressed at the end of this post seem to be confirmed - apparently you currently need a battery installed in the M1 in order to update its firmware. If this is correct, it's a big problem for people running their M1 solely on the mains charger, especially if the M1 is in a remote, difficult-to-access location. I believe the firmware needs to be changed so that if the M1 is being run without a battery, using a sufficiently powerful mains charger (see the link in the next paragraph) then firmware auto-upgrades should be allowed to proceed. If you agree with this proposal, please hit the Kudos button - it may draw attention to this post. I'm using my Nighthawk M1 (MR1100) without its battery, powered only by an upgraded mains charger for 24/7 internet access at home. This morning I found I had no internet connection and the LED on the M1 was flashing orange rapidly but dully. I decided just to turn off the power, wait a few seconds and then turn it back on. This probably wasn't a good idea - it would have been better to try to shut it down by holding the M1's power button in until it shut itself down "gracefully" - I guess I could have "bricked" the M1 if it had been in the middle of a firmware update. Anyway, after powering back up, thankfully the LCD screen then displayed a progress bar and a message similar to "Updating - do not power off". The progress bar moved fairly rapidly but when it reached 100%, the LCD screen went blank and the orange LED started flashing rapidly again. I'd noticed previously that in the web-based interface under Settings > Adminstration > Firmware Update, there was an advisory note saying "Software Update unavailable when battery level is below 20%", so I suspected that running the M1 without a battery might cause issues when it tried to auto-update the firmware. I inserted the battery (already charged to around 70%) without turning off the mains charger and the LCD screen again displayed the progress bar with the warning not to power off. This time, the progress bar didn't move smoothly to 100%, it jumped in stages and each time the LCD screen went blank for a while. When it reached 100%, the M1 appeared to reboot, possibly more than once, but eventually the normal LCD display returned and the LED was flashing blue as ususal. When I checked the web-based interface, there was a message stating that the software had been updated successfully. Prior to the update, my M1 was on firmware version NTG9X50C_10.20.05.00. It's now on NTG9X50C_10.22.03.00, which has a build date of 22nd Nov 2017. I'm in the UK and my provider is EE - it's possible that the firmware version numbers differ from country to country. I've no idea what has changed in this firmware version - on a quick glance through the interface, I don't see any new options so I guess the changes were bug fixes. Unfortunately, there's no new option to stop the Ethernet port going to sleep when running on the mains charger without a battery. However, this feature wasn't promised until Feb. It would be very useful if Netgear published a firmware update history on their site, even though they are not providing the firmware itself for downloading. At least we could then see what had changed. If you agree with me on this point, I ask you again to hit the Kudos button. Thanks.Please demystify firmware update numbers for Nighthawk M1
Can anyone please explain what Nighthawk M1 firmware update numbers indicate? I'm in the UK and my mobile network provider is EE. When I first got my M1 in Nov 2017 it immediately auto-updated to release 10.20.05.00. Last week it auto-updated to 10.22.03.00 (firmware build date 22nd Nov 2017), only after I had replaced the battery (I'm normally running my M1 24/7 on an upgraded mains charger without the battery). My web-based GUI version is now MR1H_04.01.45.00. However, the firmware numbers don't match the numbers I've seen in other posts, such as 10.16.04.04 from around August 2017 (perhaps specific to Telstra), which according to this Netgear moderator partially solves the Ethernet sleep issue, by initially turning on the Ethernet port for 2 mins after a reboot and then keeping in on if the port is terminated by an attached device. He also refers to 10.16.04.04 as being MR1 - does this stand for "Major Release 1" or something else? And he indicates that the remaining Ethernet port issues should be solved in MR2. How would the update release codes change to indicate MR2? And when is MR2 likely to be released to the various carriers in different countries? The release 10.16.04.04 would appear to be a numerically earlier release than my original version 10.20.05.00, which still had the Ethernet port OFF after a reboot. So how are these release numbers determined? Is there a different code for each country or perhaps each mobile network provider? If there's no uniformity with the numbering and no update history records on the Netgear website (new features, bug fixes, etc.), how on earth can users know when their own M1 issues have been solved? Please Netgear - be more open about your release numbering and provide update history records on your website so that users in different countries know where they stand.New Orbi user here. Should I update from V1.12.0.18?
I installed the RBK53 system and its working really well right out of the box on V1.12.0.18. Should I leave well enough alone or go ahead and update the firmware? I’m comfortable with doing these sorts of operations but have noted that some users have had bad results with Orbi systems after updating. Is there a consensus here about whether or not to update? Thanks!Firmware update to 6.6.1 and all encrypted shares lost
Hi all, I have just updated the firmware from 6.5.1 to 6.6.1 on my NAS and after reboot, all of the shares on the encrypted RAID 1 (drive1 and 2) have dissappeared. On the other drive (not encrypted drive 3) everything is fine. All the apps have dissappeared too (did not have many), but i can imagine they were on the main raid 1. In the logs i can see that even the snapshots have been removed, but i dont know why. Wish i had never bothered updating it. After several restarts i had a few issues whilst booting trying to read the encryption key at around 45% and kept giving memory errors (out of memory+354) but finally i have now got back into the NAS admin but both disks (1 and 2) are red (inactive volumes). I am pretty desperate to recover the data, can the NAS run some form of disk repair? What should i do? I am not very familiar with linux/ssh but I can follow instructions. Can anyone help me?5.9KViews0likes11CommentsFirmware Update on CM400 Docsis 3.0 cable modem
According to the website, I have to contact my ISP to upgrade my firmware on my modem, but my ISP says that the manufacture sends out updates to them and it will eventually be updated. My only issue is that Netgear's website shows that I should be on firmware 01.01.13 and I am currently on 01.01.08. Is there a way to get my firmware updated? I am having random connectivity issues and I am trying to troubleshoot both my cable modem and wireless router. Two separate issues seem to happening. I have wireless access but no internet, and after a reboot of the cable modem everything is fine. Other issue is wireless drops and reconnects. Everytime I have to reboot the cable modem. Any answers would be appreciated!5.7KViews0likes1Comment
