GSS116E problem
1 TopicGSS116E blinking on every port constantly
Hello, The switch is blinking on every port constantly. It is not possible to get a connection to the switch over the network. Just after switch on everything seems to be ok, bo only for about a few seconds. I have disconnected the switch from the network and reset it, but still the problem persist. Is it typical problem for this model? Is there any way to repair it on my own? I will be grateful for your help. Kind regards A.Solved1.7KViews0likes4Comments
