ReadyAS's avatar
ReadyAS
Guide
Feb 16, 2018
GSS116E blinking on every port constantly
Hello,
The switch is blinking on every port constantly. It is not possible to get a connection to the switch over the network.
Just after switch on everything seems to be ok, bo only for about a few seconds.
I have disconnected the switch from the network and reset it, but still the problem persist.
Is it typical problem for this model?
Is there any way to repair it on my own?
I will be grateful for your help.
Kind regards
A.
  • Hi @ReadyAS,
    There is no option to download logs from the GSS116E switch.  If ever the problem happens again, I suggest you to re-upload the same firmware v1.0.0.6 to the GSS116E switch then reset it back to factory defaults settings.  Afterwards, reconfigure the settings from scratch and observe if the same problem occurs.
    You can download firmware v1.0.0.6 here.
    DaneA
    NETGEAR Community Team
  • Could it be a problem related with any capacitor? In power supply for instance?
    • ReadyAS's avatar
      ReadyAS
      Guide
      Yestarday I reseted the switch, waited same minutes after switch-off, switched-on again and the problem persist. I tryied a few times to run the switch.
      Today after switch-on the switch works fine (20 minutes for now, but it works fine).
      Very nice, but it is strange and I do not have confidence it will work.
      How do you think, is this switch good or not?
      Maybe that kind of problem sometimes happens in this switch? :manfrustrated:
      I do not see any logs. Is there any way do check what happened?
      The firrmware is the newest - v1.0.0.6.
      • DaneA's avatar
        DaneA
        NETGEAR Employee Retired
        Hi @ReadyAS,
        DaneA
ProSupport for Business
