ReadyAS's avatar
ReadyAS
Guide
Feb 16, 2018
GSS116E blinking on every port constantly
Hello, The switch is blinking on every port constantly. It is not possible to get a connection to the switch over the network.  Just after switch on everything seems to be ok, bo only for about a f...
  • DaneA's avatar
    DaneA
    Feb 18, 2018
    Hi @ReadyAS,
    There is no option to download logs from the GSS116E switch.  If ever the problem happens again, I suggest you to re-upload the same firmware v1.0.0.6 to the GSS116E switch then reset it back to factory defaults settings.  Afterwards, reconfigure the settings from scratch and observe if the same problem occurs.
    You can download firmware v1.0.0.6 here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
