ReadyAS
Feb 16, 2018Guide
GSS116E blinking on every port constantly
Hello, The switch is blinking on every port constantly. It is not possible to get a connection to the switch over the network. Just after switch on everything seems to be ok, bo only for about a f...
- Feb 18, 2018
Hi @ReadyAS,
There is no option to download logs from the GSS116E switch. If ever the problem happens again, I suggest you to re-upload the same firmware v1.0.0.6 to the GSS116E switch then reset it back to factory defaults settings. Afterwards, reconfigure the settings from scratch and observe if the same problem occurs.
You can download firmware v1.0.0.6 here.
DaneA
NETGEAR Community Team
ReadyAS
Feb 17, 2018Guide
Could it be a problem related with any capacitor? In power supply for instance?
ReadyAS
Feb 17, 2018Guide
Yestarday I reseted the switch, waited same minutes after switch-off, switched-on again and the problem persist. I tryied a few times to run the switch.
Today after switch-on the switch works fine (20 minutes for now, but it works fine).
Very nice, but it is strange and I do not have confidence it will work.
How do you think, is this switch good or not?
Maybe that kind of problem sometimes happens in this switch? :manfrustrated:
I do not see any logs. Is there any way do check what happened?
The firrmware is the newest - v1.0.0.6.
- DaneAFeb 18, 2018NETGEAR Employee Retired
Hi @ReadyAS,
DaneA
