LAN settings
1 TopicAC1900 grayed out internet, LAn, Wan setting under advanced steup
On PC have both lan and wifi. Connected to router via wifi , wwwrouterlogin.net. Got to advanced after loging in, went to setup. Dropdown shoes Internet, WAN and LAN grayed. Can not activate them. NOTE: I previously set the base IP address for wifi ip address connection to 192.168.2.2 to seperate lan/wan from wifi. Hard reset with button on back of router did not chane that back? Any suggestions?Solved12KViews0likes2Comments
