LED status
1 TopicSatellite Connection Status
Is there a way to determine what the connection status is between router and satellite? Devices are showing as attached to the Satellite on the Attached Devices page. Not really sure if I can tell if the placement is optimal or not. I assume it is ok becuase the Satellite LED ring is off. The Router ring slow blinks magenta but that scenario does not seem to be covered in the LED Behavior section of the manual and I don't really know what that means.
