M7300-24XF
1 TopicNeed Operational Code for XSM7224S
Hello, I am troubleshooting a problem with our XSM7224S ProSAFE switches and seem to have made it worse. The switch was not able to save the running configuration over the startup configuration (the switch would simply hang - we even left it "saving" for three days in case it was simply taking an abnormally long time). And when we aborted the save attempt by resetting the switch, it rebooted with default configurations. In trying to troubleshoot this we noticed that we were getting an error about the backup image CRC not being valid. And the switch was booting off image 2. So I tried copying image 2 over image 1 in the Dual Boot Configuration and now when the switch resets we just get the boot menu with the following error: "operational code CRC is not valid you must load new code". Unforunately we did not backup the operational code for the XSM7224S (and are not even sure how to do this). I have scoured the forums and Google and cannot find anywhere to download a new copy. Does anyone know where it can be found? Thanks!Solved3.1KViews0likes3Comments
