MAC address
4 TopicsBlock/Allow Schedule Via Mac Addresses
Dear Netgear, 1. The mac address control (block/allow) ability is pretty weak. I really need the ability to schedule device level access, preferrably by mac address, via a time and day schedule. 2. Additionally, we need override buttons on the Genie apps to immidiately block and release internet access via the router. Push a button, it disables access. Push it again, it resumes access. Furthermore, an override button if (and only if) mac address scheduled controls have been enabled, as described above. Push a button, it overrrides the schedule. Push it again, the schedule resumes. Nothing is perfect, right? I mean, what if my pregnant wife wakes up at 3:04am and wants to Google 'pickles and ice cream' and her shiny new iPhone is blocked via schedule? Bad husband! It easy.... just copy paste the code from one of your other packages. I mean, we're talkng about the grandaddy Netgear Tri-Band Nighthawk R8500 four antenna monster here aren't we? We need souped up software to go along with that drag racing wifi router. How about RGB LEDs for those antenna tips while we're at it? (JK) MikeParental Controls: Blocking device based on time schedule
There are multiple inactive community discussions dating back several years with people asking for the ability to set time schedules for individual devices (using MAC addresses or whatever). For example, I want to turn off wifi to my kid's device at a certain time of evening on a school night, but not affect all devices. I may want to have a different time schedule for a younger child than an older child. I may want to limit access to wifi at different times of the day. There should be clear, straight-forward solutions to these issues. Here is a response from Netgear from back in 2015: "Re: Blocking device based on time schedule NETGEAR is working to implement the feature in the near future. You may check the updated FAQs. http://kb.netgear.com/app/answers/detail/a_id/24580/~/c3000%2Fc3700-faqs Regards, JamesGL Community Team" Why is this so difficult? Why doesn't Netgear answer this request after so many years?? This should be at the top of the list of any parental feature offered!!2.1KViews4likes1CommentC3700-100NAS is blocking ip Camera. I cannot see the ip address at all and do not know mac address
Normally, I have an issue setting up a new ip camera, because the router blocks the new ip address immediately. When the router blocks it I am unable to see the ip address at all, not even in the blocked attached devices. With the other cameras I have setup I was given the mac address (located on the camera or manual) and able to manually add it to LAN. This camera I do not have access to the mac address without being connected to it. Since my router is not even showing it attached (not even in blocked attached devices) I am at a loss of what to do. Can anyone walk me through a way to add the camera, please? Thanks in advance!!2.3KViews0likes2CommentsVPN controlling access
I have just got a R7000 router and i am wanting to use the openVPN on it. My main worry is security as it just seems to generate one set of files with no user name or password support for each user. I was wondering, if I use "Configuring Access Control on Nighthawk Wi-Fi Router" to allow only known MAC addresses to access my network, would that also be true when using the VPN, such that if the MAC address was not in the "access control table" it would'nt allow VPN access even although the user had the files. Its just that if anyone ever got access to the files i would have to turn off the VPN feature as they are same files. So I'm hoping that this will be a possible solution to my dilema, using "Access control" features. Hope it makes sense and someone has come across this problem before.Solved4.1KViews0likes3Comments
