Nighthawk c7000
1 TopicDownstream LED flashing
I have the Nighthawk c7000 cable modem router. It was working fine since I bought it in April 2016 until recently. For the past few weeks the downstream green light has been flashing. I restarted and rebooted it several times. I also set it back to factory reset, all of which didn't help the issue. Yesterday night the light finally stopped flashing and was solid green, which I thought the issue was corrected so I marked my first post as having the solution. This morning the light is flashing again. Any ideas on how to correct this?Solved55KViews0likes2Comments
