Nighthawk configuration
1 TopicNighthawk AC1900 (R6900)
Hi I was using this wifi router along with netgear c3700 wifi modem with com cast xfinity My C3700 ceased working , i have replaced based my modem with Arris SurfBoard SB6190 I'm able to browse the internet if I connected the etherernet cable in the LAN Port , if I connect the same cable in R6900 Light indicaator shows its connected to internet but not able to browse it , I tried the reset button and also tried to login on the router login page http://192.168.1.1/ or http://192.168.0.1 with another lan cord physical connnected to the router but not able to reach the settings page even reset is not completely doing the factory reset mean to say replacing the factory ssid and password configuration Any help how to solve this issue is greatly appreciated Thanks, sundherSolved7.8KViews0likes14Comments
