No Volumes or USB disks
3 TopicsReadyNAS 102, soft v.6.10.4 - lost volumes
I have this NAS with 2 sata 2TB Samsung HD204UI discs, set as RAID. I don't remember which one - RAID 1, RAID0 or X-RAID - the last one is the most probable. I haven't reach the NAS for a few months. I tried yesterday, and I have the info that I have no volumes, but when I go to System/Volumes, there is an alert "Remove inactive volumes to use the disk. Disk #1, 2." I found similar problem here, but the solution was to use "Saved USB Encryption Keys" - I have never created any and I have never used any, so I do not have any. Is there any other way to get to data on the device? It was a family archive (photos, music, videos, etc.) and it would be a serious tragedy, if we loose it. Please, help.51Views0likes1CommentReadyNAS 102: When using ReadyCLOUD on my desktop I get the message "No volumes or USB disks"
Hi. When using ReadyCLOUD on my desktop I get the message "No volumes or USB disks" trying access my information on my ReadyNas. OS 6.5-0. Status: In good shape. I have tried to get a solution via the community, but with no success. I have tried diiferent browsers: Chrome, Edge and Firefox. I have checked so that the checkbox for proxy server is unchecked. I have tried to reinstall the ReadyCLOUD app. I have restarted the NAS several times. Now I have ran out of ideas. Do you have any? When I use the ReadyCLOUD app for Andriod in my mobile phone or tablet, I'm able to reach my files... I'm also able to reach my files on LAN. Best regards Per LundinSolved4.6KViews0likes13CommentsNo volumes or USB disks error message on readycloud
Hello, I have an error message "No volumes or USB disks" that appear when I try to access my nas from readycloud website. I recently changed home as well as router. The most strange thing is that I can access my nas and its contents through the readycloud client application but not from the website. Can you help me on this please? Thank you in advance, Regards, Laurent3.8KViews0likes2Comments
