Not Redundant
1 TopicError Volume data Raid Level 1, Not Redundant
Firmware 6.5.2 After adding a second 2 TB WD RED HDD both disks are being recognized and have a green check But there is an error saying Volume Dta: RAID level 1 , Not Redundant; 679.5GB (38%) of 1.8 TB used. Diagnostics: Successfully completed diagnostics System Disk 1 has 1 Current Pending Sectors Logs 2016-09-26 12:35:25: md/raid1:md127: sda: unrecoverable I/O read error for block 64161792 2016-09-26 12:26:40: md/raid1:md1: Disk failure on sdb2, disabling device. 2016-09-26 12:26:35: md/raid1:md0: Disk failure on sdb1, disabling device. 2016-09-25 10:39:05: md/raid1:md127: sda: unrecoverable I/O read error for block 64161792 2016-09-24 10:51:21: md/raid1:md127: sda: unrecoverable I/O read error for block 64161792 2016-09-24 10:30:47: md/raid1:md127: sda: unrecoverable I/O read error for block 64161792 RAIDar -> admin -> system -> overview says that the system is degraded. RAIDar -> admin -> system -> volumes shows two disk - RAID 1. Data 270.62GB; Momentual 408.86GB; available 1.18GB: type RAID 1. Unfortunately I do not have a high skill experience to understand what is wrong. Anybody who could help me? Thanks.Solved5KViews0likes13Comments
