PCI DSS
1 TopicM7100-24X - No support for TLS 1.2 on management connections?
New poster here so hi everyone. :smileyhappy: Just wanted run a question by the experts here. My company has just aquired a wildcard certificate from Digicert which we're planning to use for HTTPS management connections to each of our network devices and various servers. After some trial and error, I managed to get the certificate installed on one of our M7100-24X switches and I can make a properly secured connection to its web console. However, I noticed in the HTTPS settings and in the subsequent connection information that the most up-to-date cipher suite it can use is TLS 1.0. As we are in the process of making our organisation PCI DSS compliant, I would like to be able to use TLS 1.2. Have any of you got experience in this area? Does anyone know whether it is possible to enable TLS 1.2 on Netgear switches? Pehaps Netgear are aware that this needs addressing and are working on it for a future firmware release. I've opened a support ticket but any advice from the community would be helpful in the meantime. Thanks.3.4KViews0likes3Comments
