Parential Controls
1 TopicNetgear Genie - Network Map
The network map needs more work. The current version assumes that your primary network adapter is the subnet you want to scan. That is not always the case. We need an option to specify the subnet to scan for devices. In reality it should be reading the ARP and DHCP table from the main internet router and the application should not be scanning the network. It would also be nice if the device master list was actually stored on the router its self. Each individual Genie apps seems to be generating its own list. The network map seems to have a limit on the number of devices. I have about 55-60 IPed devices in my house and I can only see about 30 at a time. Hello Netgear its the IoT age and everything is on WiFi now... I love that parental controls and network map now allow device by device profiles settings. However, given the limitations to the network map feature above its hard to control every device, from every Genie application and from remote locations.76KViews15likes7Comments
