Password Reset
3 TopicsUnable to log in to ReadyNAS (RN31600)
Hi, I am restructuring my NASes and I jut installed 6 new Seagate IronWolf 4TB drives into my ReadyNAS RN31600 nas and I have been locked out of the device as my password and the default password for this device are not recognised. The NAS is still "resyncing" the drives, is that the reason why I cannot log in. I thoght I saw a message flash past saying a factory reset was just done, but the default password does not work at all. Will I be able to log in once it has resynced the drives? Thank you in advance, Rick.Solved879Views0likes1CommentWebpage for ReadyCLOUD password change hangs if using an expired link. #27447891
If you accidentally use an expired link that is in your email (from a ReadyCLOUD password reset / "Forgot my Password"), the password dialog hangs without an error message. Password is not changed. Although it is a user error to use an expired reset link, the password dialog should not hang and an error message should be given. This has been recreated for NetGear. This is NetGear case number 27447891. Has anyone else experienced this issue?2.7KViews0likes3CommentsDoes OS Reinstall *REALLY* reset the Admin password?
I'm helping a nonprofit that has all their data locked up in a ReadyNAS NVX 4250... and no records on the recovery email or PW. I've used the front panel to reload the OS. RAIDar does find it, and shows that it is running an older OS version -- 4.2.5 BUT... I can't log in to the admin interface. Supposedly, an OS reinstall will reset the admin pw. But neither of the defaults work: password, netgear1. SO... does the Admin PW actually get reset on OS reinstall? Can I force an OS *upgrade* somehow (maybe using a USB memory stick and the front panel?) Any other ideas? Thanks, Pete2.7KViews0likes4Comments
